Car won't start, need some simple help...
  • Thread starter Thread starter EL1NOR
  • Start date Start date Mar 16, 2004
EL1NOR
227
Hampstead, NH
Mar 16, 2004
  • Mar 16, 2004
Hi guys,
Well the car's been stored for the winter and I decided to turn it over again today since I haven't in about 2 weeks. The battery is charged fully and I even used a jump starter to try and turn it on but nothin'. The motor doesn't turn over. I just hear a loud tick that goes very fast. It sounds like taking a wooden spoon and rubbing it against a fence as you walk by.
Battery is good... not getting a turnover. Just a fast-tick.
Any ideas? Starter? Solenoid? What's the difference? lol
I'm new with my baby when it comes to engine details.... could use some simple help.
Thanks,
-Timbo
I
Ian70mustang
18
San Diego
Mar 16, 2004
  • Mar 16, 2004
Sounds like the solenoid. its only a $5-$10 part so just replace it.
O
Ozsum67
Too much thin air
5,152
Eastern Colorado
Mar 16, 2004
  • Mar 16, 2004
You answered your own question. You don't need us.
F
FIRE14142002
55
Jackson, MS
Mar 16, 2004
  • Mar 16, 2004
sounds more like there is not enough juice getting from the battery to the solenoid. the battery posts need to be cleaned and check to see if all connections are tight. this is nothing more than a voltage problem.
syberjunkie
22
KC, BABY!!
Mar 16, 2004
  • Mar 16, 2004
I agree with FIRE14142002, I had this problem on my '70. I am too cheap to buy a battery cut-off switch so I just unhook the batt. cable when I don't plan to drive it for a couple of weeks. anywho, if i don't get the batt. cable back on tightly or if it is not clean, than I experience the same conditions you described.
RGS0907
429
New Jersey
Mar 16, 2004
  • Mar 16, 2004
Also check the other end of the ground wire. Clean that off & retighten that as well.
Oz... You're starting to sound like SuperDave
G
Resolved Please help! (starting issue)
  • Ghoste
  • May 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2025
Ghoste
G
Another no start thread.. pls help
  • Sarah84eyedfox
  • Apr 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2025
AeroCoupe
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
D
Electrical Grinding when starting car, now car won't start at all
  • dqureshi06
  • Apr 22, 2024
Fox 5.0 Mustang Tech Jun 30, 2024
Mindseye007
C
Fox A4LD Install Issues, Crank from Solenoid, No Start
  • Crabpocalypse
  • Oct 28, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 9, 2024
