  • 1994 - 1995 Specific Tech
car wont start sometimes,had to cycle key
  • Thread starter Thread starter 89llx
  • Start date Start date Feb 23, 2011
89llx
5 Year Member
Aug 31, 2009
302
Feb 23, 2011
  • Feb 23, 2011
I have a 95 gt sometimes it wont start, I checked fuel pressure and it was low ,so cycling key did pull up the fuel pressure to 38, on my gauge, so is my fuel pump bad?
thanks
HISSIN50
34
129
Feb 24, 2011
  • Feb 24, 2011
Does it crank when it won't start?
When you don't cycle the key and it won't start,
if you cycle the key, does it start immediately?
89llx
5 Year Member
Aug 31, 2009
302
Feb 24, 2011
  • Feb 24, 2011
yes, it cranks, I put a pressure gauge on the fuel rail and when I first hit the key I get 20 pounds of fuel press, after I cycle the key it will go up to 38 pounds, yes cycle the key fires it up
thank you soooo much!
HISSIN50
34
129
Feb 24, 2011
  • Feb 24, 2011
If you have fuel line crimping pliers, you can try to ascertain where the issue is. The most likely sources are a weak check valve or the FPR.
Otherwise, you could prime it a couple of times before trying to start it or let it crank for a couple of extra seconds while it builds pressure.
9
94gt5.o
177
ferndale WA
Feb 24, 2011
  • Feb 24, 2011
But also could be a bad fuel filter maybe. Does your fuel pump whine real bad?
89llx
5 Year Member
Aug 31, 2009
302
Feb 24, 2011
  • Feb 24, 2011
no it does not whine,too much- but the filter is an idea too
RIO5.0
6,892
N.H.
Feb 24, 2011
  • Feb 24, 2011
Odds are it's the pump...super common on these cars. A new pump will cure it for awhile, then it starts all over again...been there. Everytime it builds 38 psi or so it'll lite right off, anything less it cranks...I use my fuel pressure gage on the cowl and can see it.
Its a pain to change and letting it crank is a drag to boot....use the 3 time key on trick til you feel like getting at it. Mine did it for years...it's more aggravating than anything else....specially if your in front of a bunch of Chevy guys and it just cranks.....
J
Jaffman088
14
  • Mar 1, 2011
Sometimes my 94 fires right up, and others i have to crank it a little bit, or even a few times. I can definitely hear my fuel pump whine pretty good while driving. I also feel that it lags sometimes. Also, do not have a pressure regulator. Could that be a pump issue?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Mar 2, 2011
  • Mar 2, 2011
How much gas do you have in your tank. Fuel pumps only fail when the tank is slap ass full.
Kurt
9
94gt5.o
177
ferndale WA
Mar 2, 2011
#10
  • Mar 2, 2011
  • #10
how so id like to know.
toyman
1,944
54
79
Vernon BC
Mar 2, 2011
#11
  • Mar 2, 2011
  • #11
Be assured you have a FPR if not aftermarket then the OEM unit.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Mar 3, 2011
#12
  • Mar 3, 2011
  • #12
Murphy's law. It only fails when it's full, so that you have to drop a full fuel tank to change it out.
Kurt
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
