I'd have to look at my O2 harness to be certain but it looks like the blue wire is a ground of some sort. What you would be concerned with are the black and white wires...anything that connects to the circuit.
You can get to the fuel pump connector. It should be about center of the bumper on top of the tank. Follow the instuctions in my thread. Disconnect everything in the circuit and then reconnect one at a time. When the fuse blows you have found your problem. Might help to have someone with you to listen for the pop.
Or better yet...check the areas where your rear end work was performed. Could be something close to it. Look closely at the fuel pump wires. To really trace them out you'd have to drop the tank but you may find it before it comes to that.
The problem with doing this is taht, my car doens't blow the fuse as soon as I turn the key to the ON position. I can drive around very slowly, but as soon as I hit around 4K rpm, the fuse blows.
