  • 1994 - 1995 Specific Tech
car wont start!!
  • Thread starter Thread starter mootang
  • Start date Start date May 21, 2006
mootang
907
texas
May 21, 2006
  • May 21, 2006
Ok so it's not the mustang! its a mercedes that i was going to buy for 100 pounds for my dd. it ran fine yesterday when i test drove it but today it would not start. I've checked everything i could. it seems to be getting spark(i put the timeing light on each wire and it was flashing) I havn't checked fuel yet because I don't even know how on this car. I also checked all the fuses. it has an old cylinder shaped coil kind of like the old ford ones and when I checked the voltage on the two screws it was only 1 volt (not sure if that is a problem or not).
P.S. it just cranks and doesn't fire at all. cranks pretty strong though!
thanks for taking the time to help me
scott
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
May 21, 2006
  • May 21, 2006
Do you have fuel pressure? Do you hear the fuel pump cycle when you turn the key to acc? You may need to take off the gas cap and stick your ear to the filler hole to hear the pump cycle when someone else turns the key to acc.
Does it have a schrader valve at the fuel rails to test for pressure????
Scott
mootang
907
texas
May 21, 2006
  • May 21, 2006
no shrader valve, that's why i don't know how to check it.
HISSIN50
34
129
May 21, 2006
  • May 21, 2006
Please post info on what sort of engine, fuel delivery, etc this car has.
Scott's line of thinking is what I had in mind too. You could pull a plug nd see if it's wet.
Good luck.
mootang
907
texas
May 21, 2006
  • May 21, 2006
thats a good idea on the plug! thanks
its a 190E 4cyl. gas engine.
mootang
907
texas
May 27, 2006
  • May 27, 2006
Ok It started today and I could here the fuel pump prime! before when it wouldn't start I could not here the pump prime! so what would cause the fuel pump to not work and then all of a sudden work again! does this mean that it is on its way out or would this be a wiring problem?
thanks,
scott
HISSIN50
34
129
May 27, 2006
  • May 27, 2006
Scott, it could go either way. I would be more inclined to look for a bad connection (corrosion, resistance, etc) than a faulty/failing component. That is just my edumacated guess given the climate across the pond there.
Good luck.
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
