car wont start
i cant win
GOODFASTANDCHEAP-yea i checked to make sure the timing was right i pulled the plug and stuck a 1/4" wooden dowl rod about 10" long down in the hole and turned the crank with a big socket and ratchet until it was all the way up but before it started to go down and the rotor was pointing pretty close to the #1 and yea her car is priority now. its being a pain in the butt. and does anyone know why there is a wells box on my car? i thought those where for carb cars.
302ROLLINHARD- there was no gas on them. i dont think gas is making it through the injectors.
can anybody. tell me what would cause gas not to get through the injectors. and how come it wont start when i spray starting fluid in it.
The car should at least cough when starting fluid is sprayed into the intake. That is kinda weird.
After ensuring you have key-on 12 volts to the injectors (you can use a test light for this since the 12 volts is constant), I'd ensure the TPS indeed is still at near 1 volt. If the signal return is ~3.71 volts or greater (while cranking), the injectors shut off.
The noid light will really help. They are very inexpensive and at better parts stores (if there's a Pep boys near you, they should have them, for instance).
If your plugs have not been wet, the fuel side is a place to spend some diagnostics time.
Good luck.
I've never heard of a "wells box" either.
I agree with Hissin50, noid light.
--AND--
You said you put gas in it "from a can" if you're sure there was no contamination, did you check to see if your fuel system is holding pressure? How much fuel is in your tank?
That said, I'm running out of "theorys"...go back to "the list", and take it one step at a time.
the can
ye athats what i thought at first maybe when it ran out of fuel it picked up trash and clogged the fuel system but i undid the supply line and stuck it in a bottle and it is getting GOOd pressure. im gonna get "the list" and go over it step by step again this after noon if i dont get any progress i will let yall know and HISSIN i checked voltage on one of the injectors and im getting voltage to it.
injectors are pulsing
ok guys i got a noid light. (those little things aint cheap) and my injectors are getting pulse to them so now what? TPS-.97 fuel pressure is good im at a loss. i hate to do this but its about to get taken to the shop if i dont figure it out soon.
Apologies if you've done this and it's a little basic...
I hate to belabor this, but when you made sure the #1 piston was all the way up, are you SURE it was on the COMPRESSION stroke?
And when you pulled the fuel line to check if you had pressure, it seems to me that only showed that you have flow...is the return line holding pressure? When you turn the key on, the pump runs for about 15 sec and then stops, right?
Gas cap tight and little round fuel door at the filler neck closing?
timing is good
yea i im getting good pressure.i checked with a tire gauge the other day and a fule gauge today the tire gauge said 28 the real gauge said 32 and i have good spark it would nt spark on the compression stroke would it? or does it? wel the cars distributor was on tight when we ran out of gas and i havent pulled the distributor and it has spark and fuel so now its getting weird. one last thing im checking spark with a screw driver stuck in the plug wire and when i pulled the #1 plug the spark seemed week think maybe the plugs some how where on ther last leg and the pereated atempts at cranking made them bite the dust? im gonna get some plugs toady and try that. might just up and crank and if it does im gonna be seriously P.O. and glad at the same time. but anyways thanks guys.
My point about the static timing is, you need to eliminate the possibility that you may have sheared a distributor gear pin or the crank keyway - stranger things have happened. If it's one of these probabilities, it's possible that either gear affected may have spun any number of degrees. You can always just pull your dis to check the gear, too.
You should have a nice blue spark at the plug, not orange or yellow. Cranking the car shouldn't have worn out the plugs, but it won't hurt to replace them anyways.
Since you have confirmed that you have good fuel pressure and your injectors are firing, and the fact it won't run with starting fluid sprayed into the intake, it's definitely starting to sound like an ignition issue.
EDIT: you did say in a previous post that your plugs don't have any fuel on them after all the cranking, so maybe you shouldn't rule out fuel problems quite yet...
Is there any chance you are holding the gas pedal to the floor while you're cranking it over? That will shut off the injectors I believe.
Follow goodfastncheaps suggestions and make damn sure you are at TDC on the compression stroke when your rotor is pointing at #1.
If that's all good, your spark may be too weak to ignite the mixture. Maybe you can inform us about this "WELLS" box you have talked about in a couple posts?
Is it some sort of ignition box? If so, I'd get the hell rid of it and see if that fixes the problem.
WELLS BOX
the wells box came on the cars with "duraspark" ignitions and for some reason or another the idiot who had it before me has hacked nto the wiring harness and rigged it in and i dont know what to do to get it off. i disconnected it the other day and i lost all spark. i pm'd jrichker about it but he hasnt replied. pulled a plug a min ago and the spark is really week at the plugs gonna get some new ones today and try that and as far as the wells box if any one can tell me how to get rid of it please do.
If you can read electrical diagrams, everything you need is on these two sites.
b]Diagram courtesy of Tmoss & Stang&2birds[/b]
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer, actuator & sensor wiring
Fuse panel layout
Vacuum routing
Autozone wiring diagrams for 89-90 model years.
i know
he just comes out of no where runs by throws a wiring diagram in your face and says good luck and keeps on truckin. i didnt see no wells box on those diagrams:shrug: . maybe i can find what color wire its hooked into and get it off. im sure i dont need it. but when i unplug it i loose spark so it might be staying unless someone can tell me how they operate in DETAIL. but thanks jrichker for the diagram it might just come in handy.:nice:
Is your distributor a Duraspark, or TFI? Is it even possible that the PO converted a '90 5.0 from TFI to DS? WHY would he do that? Is it even possible to do that at all?
If you do have a Duraspark distributor, then this '''''''''wells box'''''''' MUST be a Duraspark ignition module, which are notorious for going bad. There are tests to check it if you have a DVM. If it's bad, I think you can get a new one at NaPA for around $20.
I am truly humbled by your :owned: signage :nonono:
Maybe I should throw this one out there......
Before you go and get cocky about someone missing a post in your thread, remember those on here who are actually trying to help you. Let us not forget a certain someone who unhooked the battery from another running car that caused problems with said car and now has to deal with problems with that car in addition to the problems you now face with your own car.
I would also say that JRichker has forgot more than you will likely know about the problems you are currently having.
What's that old saying? Oh yeah i remember--"Don't $hit where you eat."
Ouch. 302Hardrollin take it easy man. All in good fun i'm sure. I can tell from your posts you are trying to help and i'm sure BK can aswell. He is frustrated with his problem just cut a little slack. I think we all need a beer. Beer always solves the problems us canadians face.
One reason that we post and and might not follow-up is that we don't have diagrams, diagnostics flow charts, etc that anticipate how someone would have boogered together the wiring.
As an example, I'm trying to help someone on another forum right now - he has a 94 GT and someone tossed a battery in the trunk (apparently a wet cell battery with no box or anything) and installed a FP relay back there (the OEM FP relay is in the CCRM in the engine compartment). There's no power to the fuel pump. The poor guy who got the car seems to be reluctant to do much testing, and without further info from him (a report of what he reads when doing the tests I outlined), it's impossible for me to try to even give my two cents.
That's the issue we run into, and so Joe or others will post whatever ubiquitious OEM charts and info we can, in hopes that it might help you to see how things should be versus what you have.
Good luck.
