Car won't start
im2damncool
249
Chico, CA
Hey all, the musty's dead. She started having troubles when during acceleration she was bogging down until you got past 3500 RPM or so. Then it would lurch a bit and start to accelerate normally. Now I can't even get her to start. I'm a super novice home mechanic and so far have replaced the fuel pump and the distributor cap/rotor to no avail. The filter's less than a year old so I don't think it's that. I tried squirting some fuel into the intake and though it didn't start it did come close. Can somebody tell me how and what to check next? I think I have spark but am not sure how to tell for sure. Otherwise emmission control stuff???
To start you need 3 things to make an engine run. Air, fuel and spark. Before you start changing things you have to determine which ones you have and dont have. You mentioned you change the pump, was the pump not working when the key was turned to the on position? Did you check for fuel pressure? Now that its changed what is the fuel pressure? Since this is a 94 I am assuming it has a 5.0L installed with a ECC computer. Pull the code by either buying a code reader or doing a search on this forum and look for the post that can tell you how to get them with out a reader. Check for spark but if it didnt fire with a good shot of quick start then you most likely have a spark issue but not being there to look i can not say for sure.
I hope this gives you a starting point. Keep us posted on your progress. BTW I live close to your location so if things drag on too long maybe I can help.
To check for spark you may want to hook up a timing light on one of the plugs and see if it lights. The other way is to pull a plug wire and stick a screwdriver in it and get it close to ground while some one cranks the engine. You can get shocked so be very careful.
Allen
I haven't checked for fuel pressure yet. The tools were pretty expensive for a one time use situation. My buddy has a fuel pressure gauge but not the special adapter for my 5oh. I read that you can use any fuel pressure gauge if you use a hose clamp. Should that be my next step? How and where do I check the pressure? Also, I have a code reader but when I hook it up it won't perform the tests to give me any codes.?.? I don't know what that means. I can say that before the car died the check engine light would come on every time I accelerated onto the freeway. Then it would go off after a few seconds at speed. Thoughts?
Cranks OK, but No Start Checklist for 86-95 Fuel Injected Mustangs
Revised 29-Jun-2007 to update TPS testing procedure for 94-95 Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse link is blown.
H.) Computer
J.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Anybody else? I just don't see a screw on that picture and I still don't know what it means to jumper something. Is it just attaching a wire from one component to the next? Sorry all but "Founding Member" just means I've been on here awhile. I'm still learning all this stuff with NO automotive or technical background. So break it down as simply as you can. Also still haven't found the starter solenoid on my '94 GT. It's not the thing right next to the battery is it? With the fusebox on it? Or is it underneath the engine back by the firewall? I traced my positive battery cable from the battery to the fusebox to the bottom of the engine then it has a branchoff which comes up past the oil filter to what I think is the coil. The rest of the cable continues on under the car and bends back toward the firewall.
