Car wont stay on!HELP
I know all about the 96/97 problems. If its the IAC, replace that and see it helps, but I know these years are bad when your reset the whole computer, when the motor is warm, it wont hold an idle what so ever. If this is the case, wait to the car is completely cold, and then immiediately drive it around for 20-30 min so it can relearn everything.
if you hold the gas down enough to keep idle, do you smell gas fumes? I just had a coil pack go bad in my '96, 2 days ago. It ran fine the night before, and next morning it would fire up, and then die. I pulled a few plug wires off, and had someone turn the car over while i looked what color spark the wires were giving off.. if you got bright cool blue spark, you can rule out the ignition problem.. but if you got orange spark, might as well get 2 new coil packs.
The IAC is your most likely culprit. Pretty easy swap.
attachment.php
