  • 1994 - 1995 Specific Tech
car wont stop over heating NEED HELP!!!!!!!
  • Thread starter Thread starter Marine18
  • Start date Start date Oct 14, 2011
M
Marine18
21
  • Oct 14, 2011
I have a 1995 cobra svt with a 351w Ford racing block bored .30 over with too many mods and add ons to list. The problem all started a week ago the car hadn't been ran in 40 days (ran perfect before this) i went to start it the batterie was dead. I jumped it out and drove to the gas station i had it stiilng their at idle and it all of a sudden started over heating radiator fluid started spraying every wear. I towed it back flushed the cooling system put a new thermostat in and it was running perfect stayed at a good temp then all of a sudden it started over heating again spraying a lot of fluid out. What eles could this be? blown head gasket? bad water pump? it needs a new belt tensioner could that be it? any help welcome....
RAYZEN CAINE
51
  • Oct 14, 2011
when I popped a head gasket my car would idle all day, but if you drove it at all it would overheat.
Do you have a electric water pump?
Fan relay working?
Do you have a fan thermostat?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,647
214
Acworth, GA
Oct 14, 2011
  • Oct 14, 2011
Sounds like a blown head gasket, or a major problem with the water pump. Explosive overheating can only be a lot of combustion gas, or no circulation at all.
Kurt
M
Marine18
21
  • Oct 14, 2011
ya i was thinking it mite be the head gasket its a mechanical water pump the fan relay is new and working i just checked it.
toyman
1,944
54
79
Vernon BC
Oct 15, 2011
  • Oct 15, 2011
Most places can test for exhaust gasses in the coolant. I wouldn't be too quick to assume a head gasket unless there were other indicators such as water in the oil or dense white smoke from the exhaust. I would just pull the T-stat and see if the overheating stops. New doesn't always mean good. A water pump failure is also a very possible.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,647
214
Acworth, GA
Oct 15, 2011
  • Oct 15, 2011
The blown head gaskets I usually see don't get water in the oil or thick smoke out the exhaust. You can run a test to see if there are exhaust gasses in the coolant.
Kurt
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
Oct 16, 2011
  • Oct 16, 2011
Another vote for the head gasket. My old V6 blew the head gaskets twice (Ford defect, had a recall on the head gaskets), and both let exhaust into the coolant. It acted just as you described, overheated quickly no matter what I did.
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
Need help 1995 mustang wiring
  • bugz
  • Apr 14, 2025
1994 - 1995 Specific Tech Apr 14, 2025
