  • 1994 - 1995 Specific Tech
Electrical Car Would Not Start After Long Drive.
  • Thread starter Thread starter CorbinGT
  • Start date Start date Aug 8, 2015
CorbinGT
17
Detroit
Aug 8, 2015
  • Aug 8, 2015
Car is a 94 mustang gt with AODE trans.
Drove the car for roughly 2 hours straight. Stopped to get gas and car would not start after. Nothing no turn over nothing. Battery power was still to the car.
I cycled through the gears on the auto shifter a couple times and I finally got it to start in neutral.
The car has never done this before. The MLPS was replaced when I had the trans rebuilt by a reputable shop. Roughly 5K miles ago.
Any ideas what it could be?
All ignition parts are new, battery plugs, wires, cap and rotor.
Could my car just of gotten hot and wanted to cool down? Would that cause this? All input appreciated.
Admin Dude
Jan 4, 1985
43,351
21,547
234
Box behind Walmart
Aug 8, 2015
  • Aug 8, 2015
List mods please.
CorbinGT
17
Detroit
Aug 8, 2015
  • Aug 8, 2015
All work professionally done. Cobra heads/intake BBK 70mm TB & CAI. BBK Shorty headers, o/r x-pipe borla catback. AODE with heavy duty internals built & converted to 470RW with shift kit, trans cooler and Stock Replacement Torque Converter.
Custom Car audio system (Professionally installed) as well
toyman
1,944
54
79
Vernon BC
Aug 8, 2015
  • Aug 8, 2015
It could be a few things. Do you know how to pull the trouble codes without a code reader? A search in this forum should locate the procedure. A $23 reader is easier and less frustrating than counting flashes.
CorbinGT
17
Detroit
Aug 9, 2015
  • Aug 9, 2015
Thank you. I pulled the code(s)...The only code I get is from my EGR valve delete... My car only did this once. It did not do it again which is the weird part about it. However I don't want to dismiss it as nothing.
toyman
1,944
54
79
Vernon BC
Aug 9, 2015
  • Aug 9, 2015
And this is probably why reman units have PIP failures that were not diagnosed.
CorbinGT
17
Detroit
Aug 10, 2015
  • Aug 10, 2015
Sorry but I don't quite understand what you mean by that toyman..
Are you suggesting the PIP sensor is bad in my distributor?
Thanks
toyman
1,944
54
79
Vernon BC
Aug 11, 2015
  • Aug 11, 2015
Thanks
Possibly, they often die a slow death. They will test okay only to completely fail later. With a reman a failing PIP passes only to fail shortly after it's installed.
CorbinGT
17
Detroit
Aug 12, 2015
  • Aug 12, 2015
Okay thank you for your help. It hasn't done it since... But I will keep an eye out for it if the problem arises again!
CorbinGT
17
Detroit
Oct 20, 2015
#10
  • Oct 20, 2015
  • #10
I know this is an old post, but I am adding to this only for informative purposes!
Car was doing the whole would not start after a long drive thing because a tiny piece of metal was stuck in the gear selector range of my car! This was due to the shop who rebuilt my AODE missed it. Eventually My car was STUCK in second gear and when I took it back in for warranty work they found the small piece of metal lodged up in there. Haven't had an issue since and I took care of this 3 weeks ago. Hope this helps troubleshoot someone else's issue.
Jman900
28
SC
Nov 4, 2015
#11
  • Nov 4, 2015
  • #11
Whoa! Glad you got it worked out.
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
