Carb and intake combo question.
Stang_1973
565
9
38
San Antonio, Tx.
I am having my engine rebuuilt this week and having a larger cam being installed. The mechanic who is doing the rebuild got the cam and said it would be appropriate for a mild engine that sees a lot of street driving. However, he said that I am going to need a carb that runs flows at least 500 cfm.
I thought up two setups, since i am on a tight budget i would like to go with the first setup but the dealer at a local performance shop said that the second setup would be more cost effective and get me better mileage.
1. Stock 2 bbl intake and 500 cfm holley 2bbl carb
2. A 4 barrel aluminum intake with a holley 600 cfm or eadelbrock 500cfm carb
What do you guys think?
run a performer intake with a 500-600 cfm carb. a 500 edelbrock or 525 road demon carb are good choices. also run a set of small tube headers, tri-y's are good for low end and mid range power, and dual exhaust as well.
I have just the setup for you. :D FMS A321 and Holly 600. It is a dual plane good for the 1500-6000 range. I had it on my bone stock 302 and it kicked a**. With an engine pulling better from a rebuild it will be real nice. PM me
He is right, you would be better off with #2, if you can afford it.
I think it itis pronounced kind of like "Y" as in "Y" and "und" or "ind"
"Y"-"ind" = Weiand
"Y"-"und" = Weiand
I dont know but thats how i say it.
Any way I am going to go ahead with the 4 bbl intake and most likely an eadlebrock 500. just because eadle's require less tuning and holleys are more race applicated.
