Carb For My 86 5.0
  • Thread starter Thread starter Rahim
  • Start date Start date Apr 15, 2015
R
Rahim
  • Apr 15, 2015
Hey ive got a fairly stock 5.0 1983 convertible with a 1986 5.0 engine and tranny. it was already carbuerated but the guy also put in a electric fuel pump hooked up to a switch in the car. i want to upgrade the carb and fuel line what do you guys recommend? i want a 600cfm manual choke carb. with a electric fuel pump do i need to run a fuel pressure regulator??
7991LXnSHO
wanna catch the space herp
7,387
2,745
194
Kearney, NE
Apr 15, 2015
  • Apr 15, 2015
Holley 0-1850S , Holley 600 cfm 4-bbl Carburetors | Holley
Add a quick change secondary spring housing and you are good to go. I had a used one I rebuilt on my 79 and it got 25 mpg highway and beat Camaros that were supposed to have Vette engines.
R
Rahim
  • Apr 15, 2015
what do you think about an elderbrock 600cfm?
7991LXnSHO
7,387
2,745
194
Kearney, NE
Apr 15, 2015
  • Apr 15, 2015
Holley were factory on Ford since 1903, they are easy to tune, parts are easy to get and they work.
If you get a new, square bore Edelbrock, I am sure it can be tuned fine too.
R
Rahim
  • Apr 15, 2015
what do i do in terms of the fuel pump. its pretty rednecked. all electric taped and what not. do i need a fuel regulator with the new carb? do i need a return line with a fuel pressure regulator from the gas tank? can i just install them into my old fuel line??\
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 16, 2015
  • Apr 16, 2015
Single line from the tank to the pump, single line from the pump to the regulator, no return line needed. You will need a fuel pressure regulator. Check the carb manufacturer for pressure settings.
Do not try to wire the fuel pump without the relay. The 15-20 amps the pump pulls will overload the circuit. This will take power away from other items on the same circuit or cause the fuse or fuse link to blow.
If you need to run some new fuel feed lines or braided hose, here's some help. The 3/8" aluminum tubing works well, but you will need a flaring tool and bending springs to fabricate the lines. Braided hose is easy to run and route, but is much more expensive. It is about $3.50-$4.00 a foot plus the end fittings, which are $3-$4 each. Fabricating hose assembles can be difficult, but anyplace that makes hydraulic hoses can do it for you for an extra charge. See Amazon Hose - Rubber, Hydraulic and Industrial Hose - since 1919 for more information.
For some help fabricating your own stainless steel hose assemblies, see
www.TurbineFun.com
For stainless steel braided hose and fittings for automotive use:
See http://www.summitracing.com/search/?keyword=stainless steel hose&dds=1
stainless steel hose - JEGS High Performance
See http://www.eaton.com/Eaton/Product...rformanceProducts/FittingsProducts/index.htm for more information on High performance automotive hose products
AN fittings require a 37 degree flaring tool. A standard automotive or household plumbing tool is 45 degrees and cannot be used with AN flare fittings. If you do, the flare is subjected to too much stress when the fitting is tightened, and is likely to fail or leak.
See MSC Industrial Supply Co. | Find Power Tools, Hand Tools, Machine Tools & More , McMaster-Carr or for the flaring tool you will need . Prices start at $85 and go up
MSC Industrial Direct – All Product Categories
McMaster-Carr
Last time I was in Summit racing, they had a 37 degree flaring tool for less than $40. It may or may not be a catalog item.
R
Rahim
  • Apr 16, 2015
so if i purchase a new carb, 20 ft or braided hosing, fuel pressure regulator, fuel filters and a few hose ends, and take her down to my buddys shop i should be good to go? would i need anything else?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 16, 2015
  • Apr 16, 2015
That depends on how good your existing wiring for the electric fuel pump is...
7991LXnSHO
7,387
2,745
194
Kearney, NE
Apr 18, 2015
  • Apr 18, 2015
@jrichker, I like the LED's in the diagram. Now our Radio Shack is closing, WHERE do we get electronic tinkering items???
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 19, 2015
#10
  • Apr 19, 2015
  • #10
Some of the Radio Shack stores will remain open according to a Radio Shack employee I talked to. See Sites-radioshack-Site to find a store in your area.
For the mail order route, you can still order from RadioShack – Do It Together
Alternate sources can be found at 10 Best Electronics Suppliers
madmustanger
29
#11
  • Jun 1, 2015
  • #11
Madmustanger here dont know if this'll help much got a elderbroc 1406 ew from speedshop for 225 cause someone thought it was what they wanted tryed it didn't work so took back no box saved me 200 bucks check with your local speedshop might get a gd deal.
Got it installed had a surging problem till rotor in distributor tore up had a local shop fix it new rotor plugs timing adjustment tweeking carb runs like a bat outa hell now just needto find out roughly what oil pressure a high millage hard running 85 5.0 should be at idle normal temps. PS mine has mechinical fuel pump
No spark. 1990 foxbody 5.0 gt
  • Boogi
  • Nov 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
Boogi
CFI to carb conversion question
  • StockerStang
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2025
AeroCoupe
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
