Carb Installation Question
  • Thread starter Thread starter estevaf
  • Start date Start date Oct 26, 2008
estevaf
194
São Paulo, BRAZIL
Oct 26, 2008
  • Oct 26, 2008
Hi, Friends.
I have just got a brand new Holley Carb for my MII (V6, 1974).
This is an original as everything else in my car.
I did came with a spacer. The one that is currently installed does not have such spacer installed.
Which one is the correct setup. Should I install this new spacer when installing my new carb.
Thanks!
stang74shelby
24
soon Indianapolis
Oct 26, 2008
  • Oct 26, 2008
Is it a phenolic spacer? or metal? :SNSign:
estevaf
194
São Paulo, BRAZIL
Nov 1, 2008
  • Nov 1, 2008
I am not quite used with phenol but it looks like a very thick gasget.
The whole for the screws, though, seems to be metalic. It around 0,5 inches thick...
Wart
I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
408
NE Ohio
Nov 2, 2008
  • Nov 2, 2008
I'm guessing it's the heat isolator 'gasket'.
Wart
408
NE Ohio
Nov 3, 2008
  • Nov 3, 2008
Estevaf, I have an idea,
How long are the carb studs? That will give us an idea what all is suppose to be on top the intake.
P
P-Zero
15
Michigan
Nov 4, 2008
  • Nov 4, 2008
Are there sleeves in the bolt holes of the gasket? Some gaskets are think because the base of the carb is imperfect, and the thicker gasket helps ensure a good seal so you dont have vacuum leaks. I used a thick gasket like that on my old Holley 4010. It was aluminum and those carbs were prone to warping and they wouldnt seal on the bottom. Also, theyre a good heat barrier between the engine and the carb, to help prevent vapor lock (fuel boiling inside the lines or carb).
-P.
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
L
2006 mustang gt has high clutch bite
  • leevikisley
  • Feb 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 22, 2026
leevikisley
L
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
