Carb Issues
nugget68
362
is there a special peice that i need for my carb to get it to shift my transmission when i kick it. right now it pretty much stays in what ever gear i'm in when i floor it. the carb is a 600 holley and the transmission is a stock c4...if so how hard it it to fix...
Just went thru this - you will need a kickdown cable for C4 trans - see site - http://www.lokar.com/interior_pages/tc_kd.htm. In addition you will need part srk4000 for Holley. Not to difficult to install. At the same time I had to change to a throttle cable instead of the rod set up I have to get it to work. Autozone had a generic chrome cable set that worked very well for me. Can probably order what you need from Lokair or above site also. good luck.
