Carb Question (Edelbrock)
  • Thread starter Thread starter mirage86
  • Start date Start date Nov 10, 2004
mirage86
78
  • Nov 10, 2004
I've got a carbed 302. On the front of the carb, (edelbrock 1405) I've got three vac ports. The middle is PCV Vac (It's hooked up) to the right is a smaller port that I've been able to determine is "full time vac" (plugged up, what's this one) and one to the left of the PCV vac that I cannot figure out what it is but it is plugged also. The carb is mounted on a spacer that has vac ports that are plugged. I've had the car about 6 mos and I bought it more on word instead of a really inspecting it. Just wanting to get a few bugs worked out till I can get it parked and have the engine redone. It's an 86 4cyl with a 302 transplant. I believe that the prob I'm having is in the carb
Thanks
battyice
153
West Chazy, NY
Nov 10, 2004
  • Nov 10, 2004
What kind of problems are you having?
The vacuum port you are calling "full time vacuum" is actually manifold vacuum. The vacuum signal is obtained from the vacuum in the intake manifold. The other vaccum port you mentioned on the left of the pcv valve is "ported vacuum".
The port vacuum signal is generated via Bernoulli's Principle in the carb's venturi. The larger the volume of air flowing through the carb, the stronger the vacuum signal at the "ported vacuum port". At idle there is very little air flowing through the carb and the vacuum signal is very small. Basically no vacuum. At wide-open throttle (WOT) and high RPM, the port vacuum signal is strongest.
Hope this helps.
mirage86
78
  • Nov 11, 2004
My prob is that at about 3000 RPM I lose power. The car starts sputtering. Sounds like it's flooded or starving for gas. When I shift gears or slow down, everything's fine until I get back up to the 3000 RPM range. I've read that the secondaries on the carb open when the primaries are about 65% open. I would guess that this is about the time my prob starts. I've read that a lot is dependant on air flow through the manifold, but I have no line hooked to the manifold just to the PCV.
Thanks
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
H
'86 New Turbo Build First Start/Idle Trouble. Full Tune specs attached
  • Heffay
  • Jul 10, 2022
  • Digital Self-tuning Forum
3K
Digital Self-tuning Forum Jul 12, 2022
Heffay
H
HELP! New fox owner power question
  • Ramennoodles77
  • Jul 17, 2020
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 22, 2020
Mustang5L5
