carb secondary help please
  • Thread starter Thread starter 93project
  • Start date Start date Aug 25, 2010
93project
549
52
38
El Paso, tx
Aug 25, 2010
  • Aug 25, 2010
I searched but couldn't find what I was looking for.....
I'm building a 308 with Edelbrock Heads, 1.9 intake aluminum, Comp cams 1.6 gold rockers and pushrods, Edelbrock 3722 cam, .499 lift both sides, edelbrock performer RPM intake, dual plane, long tube headers 1 5/8", full MSD ignition, with 6al,. this is going in a 93 gt, which has had every piece of ac/ heater removed, including vents and box under dash, several pounds of efi harness removed, no air bag, no backseat, 'glass hood, fr500 18" wheels, battery in back. I can't guess the weight it would have. It has 3.73's, T-5, no spare tire.
Now that youhave car info, what kind of carb can I use?? some tell me that since it's a lightweight foxbody, I should go dual feed carb, around 600-650. Others say vacuum secondaries are what I need since the car will only see street driving and occasional freeway blasts. I will not take it to the track anymore so..... what do you think? I do want electric choke. For DP, I was looking at Quick fuel 650, for vacuum, holley 80457s. Please help! Thanks
347HO
462
Seattle
Aug 26, 2010
  • Aug 26, 2010
I suggest a standard Holley 750dp. Depends if you know how to tune.
I would not use anything smaller than a 650.
Again, the choke horn is up to you... I don't use one.
When you have the carb installed and running, check idle vacuum before going further... if you don't have the vacuum the camshaft says you should have, you're going to have a tough time dialing it in.
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
R
1974 Datsun 620 pickup / 5.0L HO
  • RJH46
  • Aug 24, 2025
  • Other Auto Tech
Other Auto Tech Aug 24, 2025
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
9
Engine 94 GT breaking up
  • 996stang
  • Sep 21, 2024
Fox 5.0 Mustang Tech Sep 26, 2024
AeroCoupe
