I have a 95 GT I've thought about carb swap as to have a more modified engine without spending thousands, so many are like it's dumb stay EFI but to have a stout engine with EFI your talking a aftermarket intake $800+ new, injectors, throttle body and once that's done a programmable ecu and a tune... Talking well over $2000! and cam choice is important with efi. Vs intake and a carb little tuning and done with $500 brawler carb and used $100 intake. I know t's been discussed a zillion times but I'm tired of looking just to see the same responses anyway, I've looked at carb swap discussions and they always are very in depth with a ton of modifications and ripping and tearing to the point of no return. but is there a reason you couldn't just take the entire EFI assembly off (just leave the connectors intact computer up n running just let the car think the EFI is still there) put any wiring not used off to the side as so it could be re installed down the road if need be, drop an intake and carb on and toss a one wire hei and be in business? This is for function not looks, Only part that seems to be involved is the fuel supply method but that's fairly straight forward im assuming a modified pickup and an inline pump. I was even wondering if you put a TPS kit on the carb if you could retain the cruise control...? May be a far fetched idea or inst it. Any input is appreciated.
I can see it, if it's just some performance gains the EFI (electronics) stuff in stock form can support 275 HP (maybe some more) without a chip or tuner. Easy to do with a carb, and yes, pretty inexpensively too, I won't get into the extras like cruise or devaluation or that gob of wires that are now bundled up in a corner of the dog house.
