Hi all. I'm trying to get this beastie past emissions in massachussetts. She passed everything else with flying colors. They didnt say anything about the grease either
. They even looked past my fake pcv and charcoal cannister.
I attached the emissions sheet. It failed for hc 2.00/1.20 and CO 27.37/20
Nox was 2.12/2.50
CO2 was 489.42 (no limit).
Now I know I trying to pass a carbed motor on an EFI platform so I'm in for a pickle of a project. I got hold of 4 catco 2 1/2 catalysts. These things are so huge that the 2 cats back to back go almost from the longtubes to the catbacks so I only used a single pair for the moment on a cut up BBK midpipe. So
-the cats are fresh
-I am running the smogpump to the back of the heads
-no EGR (the spacer prevents this from being hooked up)
-no vacuum advance on the dizzy. I am running 24 degrees initial (I think my balancer has slipped since the car didnt run at all at 10 degrees and 24 seems a bit high). But nox was decent so I'm no worried about timing.
Holley street avenger 570 is set up pretty damn lean already 56/58 jets, 5.0 powervalve, idle set 1/4 turn above stumbling, .28 shooter with factory white pump cam, clear long secondary spring. I am running 6 oz of acetone on an 11 gallon fillup of 87 octane.
I did notice though that the car on the dyno is tipped forward.......this would affect the float levels, wouldnt it?.......lean it out since the gas is tipped away from the metering block
So what now? I heard about folks using denatured alcohol but I am already running acetone. Should I somehow wedge my second set of cats in there? The only way they will fit is if I cut the heatshields off the front pair and tuck them into the humps of the crossmember but Im worried about melting the poly bushings.
What do you all think?
Thanks for looking!
. They even looked past my fake pcv and charcoal cannister. I attached the emissions sheet. It failed for hc 2.00/1.20 and CO 27.37/20
Nox was 2.12/2.50
-the cats are fresh
Thanks for looking!
This is the car that I have and I need to get it through the inspection so I can drive it.
