Carbureted Ignition Kit?
  • Thread starter Thread starter Tman64
  • Start date Start date Jul 21, 2017
T
Tman64
52
  • Jul 21, 2017
I'm looking for a igntion kit for my 302 i will be putting into my 4 cylinder 1993 coupe. I have seen the forum about the autozone distributor with duraspark.. but i have yet to find a duraspark ignition box or any others mentioned in older forums for sale. Any kits you can actually buy that will work for carb use?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 21, 2017
  • Jul 21, 2017
I will tell you up front that I am NOT a fan of converting anything but a pure race car to carb. You will create more problems than you will fix.
However for sake of community, here are some answers that I posted to your original thread.
Diagram courtesy of /www.billwrigley.com
See http://webpages.charter.net/1bad6t/duraspark.html for more help.
Note the ballast resistor shown in the diagram: you’ll need that too
If you use a coil from a 78 or later Mustang, you don't need the ballast resistor. The stock 89 Ford/Mustang ignition coil does not need a ballast resistor
A simpler HEI ignition that uses the same distributor and fewer parts can be found here. This is an excellent resource, and I suggest that you add it to your Internet Favorites
http://www.binderplanet.com/forums/showthread.php?t=48435
Google is your friend, I suggest that you familiarize yourself with its capabilities. ALL sorts of DuraSpark boxes are available:
https://www.google.com/?gws_rd=ssl#q=duraspark+ignition+box&spf=1500680671077
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jul 21, 2017
  • Jul 21, 2017
I've ran a Duraspark and the GM HEI deal, neither ran as good as my MSD 6AL/MSD distributor combo. Granted it's a lot more expensive, but you get what you pay for.
Dan02gt
mazing how much gas smell came from that tiny hole
20+ Year Stangneter
Mar 2, 2003
909
415
113
Greenville, NC
Jul 22, 2017
  • Jul 22, 2017
How about something like this:
www.holley.com/products/fuel_systems/fuel_injection/sniper_efi/sniper_4bbl_tbi_master_kits_with_fuel_system/parts/550-511K
It has ignition control and a coil driver built in.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jul 22, 2017
  • Jul 22, 2017
I REALLY want an MSD Atomic EFI kit, but it's a hard price to swallow especially after blowing $650 on my Pro System carb. I got to play around with a Chevelle that had it on a big block and I swear I have never experienced a carbed engine with throttle response as good and I've tuned mine half to death. I would say it was even more crisp and responsive than some traditional EFI cars I've driven. I'll own one eventually but I've got more important things to deal with first. If I were just building an engine and hadn't invested in a carb or ignition setup, this is absolutely the route I would go.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 22, 2017
  • Jul 22, 2017
There are better options for this kind of conversion. The only issue I have read about with this system is drivability leaves something to be desired.
Imho fast makes a better kit.
Dan02gt
20+ Year Stangneter
Mar 2, 2003
909
415
113
Greenville, NC
Jul 22, 2017
  • Jul 22, 2017
You're right about the throttle response on some of those EFI kits. My business partner has the FAST Easy EFI 3.0 setup on his BBC and the throttle response is insane on it!
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jul 22, 2017
  • Jul 22, 2017
I've heard good things about the FAST kit too, that it basically tunes itself the more you drive it?
Reactions: a91what
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 22, 2017
  • Jul 22, 2017
Basically, a lot of the newer systems have auto tune... I do megasquirt and love it. For the 4150 conversions however it's easier for most to just buy a kit.
T
Tman64
52
#10
  • Jul 22, 2017
  • #10
That holley kit looks awesome, little pricey but im sure it would be well worth it. Wonder why its 12-14 weeks to ship it though? My car might not be ready to fire up then anyways lol
Adieu
Easy there, this ain't a dating site.
20+ Year Stangneter
Mar 7, 2002
9,531
5,187
224
Jul 23, 2017
#11
  • Jul 23, 2017
  • #11
DON'T DO IT.
I have the MSD Atomic. It sucks.
The support from MSD is laughable, and got worse once Holley bought them out. Reliability is again, laughable, less than 1500 miles in I had to replace the IAC on it. You have to run rubber hose the length of the car, and their biggest selling point, being able to run the system returnless, is a lie for most applications. (Although if you buy a Honda fuel pulse dampner, P/N: 16680-PCX-003, and install it on the throttle body, you can cheat if you're within a point or two of their criteria for returnless.)
I also have to manually adjust idle speed at the throttle body when the weather changes (wait, I thought this was part of why I got RID OF A CARBURETOR?), and it's re-learn is incredibly long if you disconnect the battery, and it runs so rich at idle your eyes will water until it does.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jul 23, 2017
#12
  • Jul 23, 2017
  • #12
Well then. I never have to mess with jetting or anything in my carb, but I also don't drive it year around.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Engine Distributorless to Distributor ignition on a 302?
  • 93CalypsoConvert
  • Sep 27, 2024
Fox 5.0 Mustang Tech Oct 2, 2024
85GTStangGuy
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
