Car's missing, please set me in the right direction
bryan0
175
Bethel, CT
Hi, I have a 99 GT with a mongoose vortech sq kit and the mph powerpipe. Lately, the car has been missing under load. If i were to put it in say 4th gear at 2500rpm and stomp on it, there would be a constant bububububububu almost like making your lips vibrate back and forth, that's the best way i can describe it.
I have the sct xcalibrator and decided to try and datalog it. I'm not to familiar with which paramaters to test. This is what i came up with:
Red = RPM
Pink = MPH
Yellow = Short Term Fuel Trim 1
Green = Short Term Fuel Trim 2
See how it drops off real quick right before the bottom says 119? That's where it was missing like a son of a gun. What could be the problem?
I'll try different paramaters and post a graph, let me know which ones would be useful. Note, I cleaned the maf to the best of my ability already, so I'm assuming this isn't the problem.
If possible you need to cancel cylinders tell you figure out what cylinder it is. And check that coil out. It does sound like a spark problem. Narrowing it down to one cylinder helps. Now if its a random missfire on any cylinder you have a different problem.
Well I replaced the spark plugs and everything seems okay now. They only had about 5,000 miles on them but they looked pretty blackened and one or two were even a little bent-looking. Thanks for your help guys :nice:
