Ok this is in regards to this thread,
http://forums.stangnet.com/showthread.php?t=416345
Car hasnt beenr unning right,
If I put my foot all the way down I sometimes get what feels like a miss and the engines holdinh back, then runs, then holds back, Just very wobbly,
I recently installed a new clutch last week, and a new TB on tuesday,
After all that the cars been messed up,
Ok,
Firstly here are the codes,
(Engine cold, Not started)
KOEO Codes first
21 ECT out of test range (What is that?)
24 ACT sensor out of test range (again whats that?)
67 Neutral drive switch open or AC on (the AC wasnt on)
Ok so now Engine Cold and started up
21 ACT sensor out of test range
41 HEGO sensor indicated system lean
33 EGR valve opening not detected
Ok so then I ran the car until up to operating temp and did the test again,
I dont think I had too much to worry about with those codes,
Ok Engine Hot
KOEO Codes
96 Fuel pump secondry circuit failure (What??)
Now Engine Hot and Running
94 Thermactor air system inopreative Left side
44 Thermactor air system inopreative Right side
What the hell Is that Thermactor air system?
Then I took the battery lead off for 10 mins, Reset the computer and then the only codes I got after 10 miles of driveing for the computer to relearn everything was
KOEO
11 System Pass
Runnning Engine
So Whats wrong with my car
I cant figure this out.
and STILL hesitates and dosent run right ONLY at WOT,
If im calm and slow on the gas pedal, its fine, but stamp on it and theres this problem,
But them sometimes theres no problem and its full power and sounds amazing,
So can onyone PLEASE help me out,
I hate things like this,
Ok,
KOEO Codes first
Ok Engine Hot
KOEO Codes
KOEO
11 System Pass
Runnning Engine
