cast crank or do I need forged?
  • Thread starter Thread starter allcarfan
  • Start date Start date May 17, 2004
allcarfan
The Answer Man
2,458
North Atlanta
May 17, 2004
  • May 17, 2004
The combo im putting together should make near 500hp flywheel hp..naturally aspirated 347. Engine shouldnt be spinning over 6500rpms. I was looking at two different crankshafts...hawks racing cast crank or a hawks racing 5140 crank. You think the cast crank would hold up on my non-daily driver?
Shane
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
May 17, 2004
  • May 17, 2004
Are you running the stock 302 block? If so cast will hold up fine, because the block will break first. If you had a sportsman, A4, Dart, R block I would invest in the forged.
I am saying this not from experience but researching sites like www.turbomustangs.com shows the block as being weaker than the internals.
TIMMY2734
1,330
Queens, NY
May 17, 2004
  • May 17, 2004
Yup, the block will give way before the crank. One other piece of advice, go with something better than a hawks crank. They arent exactly of the greatest quality and not very much good feedback....
408stroker5.0
The world would be a better place if all males jus
Mar 10, 2004
639
Bonnyville, Alberta, CANADA
May 17, 2004
  • May 17, 2004
Cast will hold up fine but it's a good feeling knowing you have a steel crank backing you up. All though the guy's above me are right, the block probably will go before the crank ever does.
I also agree with Timmy. Go with Scat instead, there crank's are great. I'd go with there 9000 Series Cast Crank which is rated for 700HP and are actually really reasonable priced. I've been using Scat Crank's & Rods for year now and am currently using one in my 408. Never had a problem with any of them. Infact the 9000 Cast Crank is probably one of the most widely used crank's on the market.
ScatStroker
110
Seattle / Santa Barbara
May 18, 2004
  • May 18, 2004
Scat; $50 more expensive, about half the headache.
If you're using a stock block a cast crankshaft is fine.
$.02
Brian
Rick 91GT
Mustang Master
95
99
PA
May 18, 2004
  • May 18, 2004
I agree with Brian, the cast crank will be fine for what you need, and I have not seen anything good about HAWK. I have used many of Scat 9000 series cast cranks with no issues...
I just built a blown 331 for a guy and it has a Scat 9000 series crank, Scat I beams and Probe pistons, it will out live the block for sure and will make over 500FWHP.
Brian has good prices, check him out scatstroker@hotmail.com
TT91
1,536
Paramus, NJ
May 18, 2004
  • May 18, 2004
sorry for the interuption..do u guys know what DSS uses when they offer their name brand cranks?
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
Engine Aftermarket Cast Crank for 4.6 Cobra?
  • Cool Beans
  • May 26, 2019
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 26, 2019
Cool Beans
Should I go forced induction?
  • paddyrk
  • Oct 30, 2018
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2018
General karthief
