Caster/Camber plate install question
Thanks to some Stangnetters I picked up some MM C/C plates. The instructions are clear and these look like a piece of cake to install. My question has to do with what happens next? I know I'll need an alignment, but will I be able to drive my car 10 miles or so to the alignment shop?
yes you should be able to drive it to a alignment shop with out any problems.
make sure your tires are close to sitting straigt up and down and they aren't turn inward or outward to much and your good to go once you have everthing tightened down.
