caster/camber plates
a885.0
Feb 2, 2004
78
CT
I just switched over to a front coil-over set up and was wondering which aftermarket caster/camber plates i should go with, i also read that i should go with a 4 bolt style instead of a 3 but i dont see many 4 bolt ones at all. Thanks
Avoid CC plates made from aluminum, or ones that have a rubber bushing. Get steel plates with a spherical steel bearing. That means Maximum Motor Sports or Steeda. There may be others with that type of construction, but I haven't heard about them.
exactly, no aluminum
upr makes steel ones but they are only 3 bolt. i think they call them the 'shark' plates. i got them for my eibachs for my 95. got the plates off ebay new for $95. havent got them on yet....hope they will be ok?
Yes, do not skimp on the quality of your c/c plates. If an inferrior bushing/bearing design is used and they fail, it WILL be an ugly situation.
MM gets my top vote (reason that I have them), or Steeda.
