  • SN95 4.6L Mustang Tech
Caster?
  • Thread starter Thread starter iamvillani
  • Start date Start date Sep 15, 2012
I
iamvillani
15
  • Sep 15, 2012
So I was looking at my new to me 99 GT and I noticed the front wheels sit back in the wheel wells more towards the firewall. And the passger side is even a lil further back then the driver side. Is this bad? Someone said my caster is off. Car does not seem to be hit. It tracks straight and no other noises or effects out of the ordinary. Steering wheel is pretty centered however there is about an inch or so play when centered. Tires seem to be wearing ok. Thanks for any input.
trinity_gt
3,125
81
99
Canada
Sep 15, 2012
  • Sep 15, 2012
The K-member locates the lower control arms. If the K has ever been out of the car and wasn't re-installed in the same position it's possible, through slop in the mounting holes, to move it rearward a bit. This would cause the wheels to appear rearward in the wheelwells.
I'd take the car to an alignment shop and have them do some measurements and, if necessary, move the K back to the correct position.
Incorrect caster can affect high speed stability of the front wheels as well as the self-centering of the steering wheel when turning.
You might check the rag-joint between the steering shaft and the rack (the joint is located just behind the driver's side engine mount) for looseness. It may explain your on-center steering slop.
I
iamvillani
15
  • Sep 15, 2012
Thank you very much for the input. I appreciate it.
I
iamvillani
15
  • Sep 15, 2012
Is the rag joint easily replaced if its worn? I have a chiltons manual and pretty good on basics.
trinity_gt
3,125
81
99
Canada
Sep 15, 2012
  • Sep 15, 2012
Here's a link to replacement in a Fox. New Edge are likely the same (just make sure you get the part for your year...)
http://www.stangnet.com/mustang-forums/threads/rag-joint.741031/#post-7955953
D
2003 Mustang Steering pulls left bad after and accident , screeching while driving help please
  • dustbustet707
  • May 9, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 13, 2025
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
