Casting numbers
  • Thread starter Thread starter raidmagic
  • Start date Start date Mar 31, 2009
R
raidmagic
30
  • Mar 31, 2009
Can someone tell me where the casting numbers are on a 289 to identify what the engine is and what it came out of? Thanks
golf4283
1,253
Orland Park, Illinois
Mar 31, 2009
  • Mar 31, 2009
remove the starter and they should be under there. If it's old you might have to take a rag to it and wipe it down.
Oh and if you don't know where the starter is it's on the passenger side towards the rear of the engine.
Mil1ion
48
  • Mar 31, 2009
Look for C5AE-6015-A or B
The for the 3 or 4 digit cast date code
ie: *5L19*
The same goes for the heads
IIRC, those numbers are in the oil galley of the head.
9
96 DOHC Cobra
542
Cerritos, CA
Mar 31, 2009
  • Mar 31, 2009
The casting numbers and casting dates will give you general info about what model year the block is for and when it was cast. There is nothing about these numbers that will tell you what it came in. The only way to get that info would be with the VIN from the vehicle it came out of. The only 289s that got the VIN stamped into them were some of the HIPOs.
D
D.Hearne
11,730
south louisiana
Mar 31, 2009
  • Mar 31, 2009
Ditto, nothing in the casting numbers will ever tell you what specific vehicle it was originally installed in. The date code will tell you when it was made/cast. The third character in the casting prefix only tells you what vehicle line the engineering costs were asigned to. Only a near complete teardown will tell you exactly what 289 it is, if it is.
T5 identification
  • 3054tony
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
AeroCoupe
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
R
Fox 1993 2.3L LX headlight harness
  • RubyRedNotch
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
AeroCoupe
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
M
Connector location
  • Mike3
  • Jun 28, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 28, 2026
Mike3
M
