jerryD
jerryD said:i have the QA1 with the spherical bearing. seem to be doing fine for me.
What a stupid comparison... A stock modified McPherson setup compared to coil overs. No crap you need them then. Fords settings are to keep the car tracking straight and NOT eat tires. Caster is ok to change out of factory settings, like someone has mentioned (for holding into the grooves), but other then that.. you go messing with toe settings too much or camber (especially camber), you will eat tires like none other. "Performance driving"stangbear427 said:You two try it with coilovers. Nevermind getting it aligned properly- it won't even stay together. It is also important to make the differentiation between acceptable factory specifications and performance driving specifications. Yes, you can get it aligned back within appropriate specs without CC plates, but Ford specs weren't for any kind of performance driving. Whether it's a streetcar or racecar is irrelevant. The worst part about the stock setup isn't even the cc settings, it's the rubber bushing at the top. MM plates are worth having just for the spherical bearing.
If it's driven on the street as a daily driver, it's not worth the money in tires to set it to your "Performance driving" specification.
Hey, somebody narrowmindedly said they weren't necessary on a street car. I have coilovers on all four corners of my streetcar, so obviously this isn't true so it's a perfectly relevant example- I wasn't making a comparison. Besides that, I drove my two GTs daily for ten years without CC plates, and noticed a significant improvement in steering control and response. Laugh all you want- far too many Mustang experts disagree with you for your opinion to be worth dog poop... and I'm not the one with a Saturn. I've also had a significant increase in life span of my tires with performance settings, because that's how I drive it. Simply lowering it and realigning it back where Ford said it belonged wasn't appropriate for how I drive it, not satisfying nor financially efficient. Maybe for you they are- you sound like the people I pass on the exit loop every day. Arguments like "why spend money on a V8? You can only drive so fast on the road" come to mind.PoopDawg said:What a stupid comparison... A stock modified McPherson setup compared to coil overs. No crap you need them then. Fords settings are to keep the car tracking straight and NOT eat tires. Caster is ok to change out of factory settings, like someone has mentioned (for holding into the grooves), but other then that.. you go messing with toe settings too much or camber (especially camber), you will eat tires like none other. "Performance driving"If it's driven on the street as a daily driver, it's not worth the money in tires to set it to your "Performance driving" specification.
stangbear427 said:Hey, somebody narrowmindedly said they weren't necessary on a street car. I have coilovers on all four corners of my streetcar, so obviously this isn't true so it's a perfectly relevant example- I wasn't making a comparison. Besides that, I drove my two GTs daily for ten years without CC plates, and noticed a significant improvement in steering control and response. Laugh all you want- far too many Mustang experts disagree with you for your opinion to be worth dog poop... and I'm not the one with a Saturn. I've also had a significant increase in life span of my tires with performance settings, because that's how I drive it. Simply lowering it and realigning it back where Ford said it belonged wasn't appropriate for how I drive it, not satisfying nor financially efficient. Maybe for you they are- you sound like the people I pass on the exit loop every day. Arguments like "why spend money on a V8? You can only drive so fast on the road" come to mind.
Toe settings, with or without coilovers, is one of the main reasons for CC plates. It has nothing to do with adjusting toe, only with keeping it where it belongs. This is an even bigger factor on the street than on the track, where your suspension isn't as likely to encounter bumps, holes, or other irregularities while turning. "Dynamic alignment accuracy is the ability of your Mustang to maintain its static alignment settings during hard cornering. This accuracy is not possible with the stock rubber strut mounts because they deflect, allowing the camber and caster settings to fluctuate, which changes the effective toe setting." Which according to you shouldn't be messed with. Driving without good plates equipped with spherical bearings IS messing with it. Unless you drive like my grandmother, in which case, why drive a Mustang?
9 Deuce GT said:Why do people that have no mods done to their cars post in the TECH section?
PoopDawg said:As for the Saturn comment? Sorry you can't afford a nice daily driver that gets 35 MPG on 87. hahah Don't hate.
Actually, I had them before the coilovers. This is my second suspension in this car, the first one is now in my wife's LX, with vastly inferior Hotchkis plates. I was rounding off tires like crazy, so we went to more aggressive settings. While they still lasted way fewer miles than they were rated for, my tire life almost doubled and they began to wear evenly. Now, with the coilovers, it's even more extreme because the car will pull 1g on street tires and so I do it every chance I get. I can't imagine how they would look with normal correction the way I drive it now. I'm not saying everyone needs CC plates, I'm only reacting to the blanket statement that they are an unnecessary waste of money on a streetcar- that isn't true. Everyone drives differently and with different setups... and again, different priorities.I know this from experiance. You make bias opinions based on your experiance with coil overs... Which change the angles and load points of your suspension, and different settings might work better for you. But if you're still using the stock setup, stock settings are just fine for any street car that rarely goes or never goes to an autocross or road course.
PoopDawg said:....... And sure, the solid bearing will help in deflection and holding the settings during hard cornering.. But you give up suspension compliance and road noise for them. Inwhich I wouldn't want to give up on a street car, that once again, never seens track time.
)stangbear427 said:....... I noticed absolutely no additional NVH from the spherical bearings in my CC plates whatsoever. NONE. For that matter, I didn't notice any from my lower control arms with spherical bearings at both ends either. ........
No, but the Layered B-52's may have89CopCoupe said:Sure, but do you think the martini's played any roll in this![]()
QDRHRSE said:As long as you stay away from aluminum C&C plates they are all pretty good .....
