Hey all,
When I bought my car, it was dropped 2" using cut-coil stock springs. The front wheels have a little bit of negative camber, which causes the tires to wear on the insides. Where I am located now, I have no access to a garage so I cannot install caster/camber plates.
Here's my situation - I'm getting new tires in the upcoming week, and I want to make sure that they wear a little better. Also, the roads around here are horrendous so I would like to raise the car back up a tad. In addition, when I installed my Bilsteins, the stock springs make my car have the ricer bouce, and its really annoying. Will Ford C-springs w/ isolators help give me some more ground clearance, stabilize the ride, and reduce the negative camber in the front end? I can probably find a shop around here that will install springs, but I doubt they would install the CC plates for a reasonable price. Thanks!
Oh if anyone is located in Ohio, do you know of any good Mustang shops?
