  • SN95 4.6L Mustang Tech
catback hitting rear end
  • Thread starter Thread starter 03MaCh1nE
  • Start date Start date Nov 29, 2006
03MaCh1nE
84
  • Nov 29, 2006
:SNSign: ok well after i installed my slp catted x the cat back is hitting the read end for some reason....why is this...is it because the cat back is hanging a little lower???
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Nov 29, 2006
  • Nov 29, 2006
It may just need to be adjusted. You can loosen the clamps and try sliding the pipes in more together some where you can tell that it will not hit anymore. its probally were the exhaust goes up over the axle. Should be easy to fix.
03MaCh1nE
84
  • Nov 29, 2006
bakos24 said:
It may just need to be adjusted. You can loosen the clamps and try sliding the pipes in more together some, its probally were the exhaust goes up over the axle. Should be easy to fix.
yea cause the left one is hitting and the right one is sitting just perfect...yea i might have to get the cat back up a little...thanks
H What 4.6
56
  • Nov 29, 2006
yea.... just play with it... eventually you will find the right spot where it will clear everything
forum155pl
520
the 509
Nov 29, 2006
  • Nov 29, 2006
i had that problem on my car with the flowmasters... i clamped em so tight that i couldnt get the pipes to slide any more up... so iwent and got a tail pipe expander and stretched it a lil, and it fit right in there... chances are like these guys are saying.. you just need to play with it..
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Resolved Three way cat converters..?
  • PonyGTrider
  • Nov 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
PonyGTrider
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
