- Oct 26, 2004
- 27
- 0
- 0
Just welded in my full-length Steeda subframes last night at a reputable shop (no hack job here) and they went in beautifully, but now I've run into a majorly annoying problem. It seems as though the catalytic converters are whacking into the subframe connectors, and i'm getting a horrid banging/bumping sound when getting off the clutch (as the motor is vibrating then) and when going ove certain bumps that would cause the motor to shake a little bit. Does anyone else have this problem, and if so, how did you remedy it? I'd like to just get an O/R X-pipe or H-Pipe but I need cats for emissions. Any help would be appreciated as this clunking noise is REALLY loud and annoying.
what about grinding the speed wings (heat sheilds) down and tack welding the edges..
There isn't anything a good grinder can't take care of
