Help. Please.
I'm not following these MM instructions very well. I'm almost 2" lower than stock, maybe an inch-and-a-half lower than stock. In Step #1, I got a reading of 1 and 1/8" between the strut shaft and the straight edge. In step #24 it mentions to "place one of the thinnest spacers on top of spherical bearing. Place three remaining spacers under the spherical bearing"
I'm not "stock", but even that step messed me up - what "three remaining spacers" are they talking about? 3 thin? 3 thick? The kit only came with 4 thin and 4 thick spacers to do both sides.
And as for me needing to "position the spacers so that the strut shaft is 1.5" higher than the dimension you recorded in step 1"
...that seems like I'd be at 1/2 inch to nearly 1 full inch above the top of the straight edge, instead of having a gap between the strut shaft and the straight edge. Seems like I'd be punching a hole in my hood if I got an inch above the "straight edge across the fenders"
Can someone give me a clue on what I should be looking for or what my spacer placement should be? Thanks.
