  • SN95 4.6L Mustang Tech
Ccrm-a/c Issues
  • Thread starter Thread starter Bigtymchef
  • Start date Start date Jun 29, 2014
Bigtymchef
  • Jun 29, 2014
Last year I replaced the AC compressor in my 2000 GT. This year when it started to get hot out I fired up the A/C and had nothing. Clutch wouldn't engage and it was fully charged. After researching for a while I narrowed it down to the CCRM on the inner fender wall. Spent the cash to get a new one and it worked fine. After about 2 weeks it kicked out again. Any ideas as to why this is kicking the CCRM???
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 1, 2014
  • Jul 1, 2014
Maybe a short somewhere. That is a pain to trace. Was there any work done prior to it going out the 1st time?
Bigtymchef
  • Jul 1, 2014
I've had the car for 2 years. This is the only problem I've had with it. Not sure what was done before I got it
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 1, 2014
  • Jul 1, 2014
Are there ANY outstanding DTC codes? Why is this important? Because some DTC codes will disable the AC by design.
Check the CCRM grounds. Check the battery negative. Check the grounds around the radiator core support.
Measure the resistance of the CCRM black wires and black wire with white stripes back to battery negative. Should be low.
Be sure to use a good battery in the VOM and zero the meter before making the measurement. It would be a good idea to disconnect the battery positive before taking resistance readings.
Reactions: Bigtymchef
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
R
PCM problem
  • Rjchild9
  • Sep 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2025
Rjchild9
R
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Paint and Body Rotten moon roof trim
  • Teen'93stang5.0
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 15, 2026
Teen'93stang5.0
J
2003, 3.8l with air conditioning problems
  • Jimb0z '03
  • Nov 3, 2024
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2024
Jimb0z '03
J
