CCRM delete
biglar
33
pine beach nj
Hi Guys can the CCRM be deleted if the fuel pump and fans are manually activated? The car will be kept EFI and tuned w/ tweecer. This car is stricklty a Drag racing bracket car NO street time at all.
Thanks
BigLar
I would think so. Without looking at a wiring diagram, I'd think you would just need to add your own fuel pump relay and fan controller. I'm gonna toss this one in tech instead of tuning for a bit more exposure.
If by manually operated, you mean that you use your own circuits (and are not manually energizing the CCRM relays), then as Matt noted, you should be able to do with away with the CCRM.
As noted, the FP and EEC will need their own relays. The low and high speed fan relays, and the WOT relay are all up to you.
