  • 1994 - 1995 Specific Tech
CCRM Module
  • Thread starter Thread starter SanDogStang
  • Start date Start date Aug 31, 2004
SanDogStang
79
Temecula/Murrieta Calf.
Aug 31, 2004
  • Aug 31, 2004
Ok where exactly is the CCRM module located on a 1995? Ive read some forums and it says by radiator, but I dont see nothing. I do have Power Control Box,black with fuses and relays in it. I need to find the fuel pump control. I think its my CCRM, cause I looked in the left rear behind tail light and no relay, only emegency cutoff switch.
Thanks
SorsCode
20+ Year Stangneter
Jun 10, 2003
1,022
432
113
St. Louis, MO
Aug 31, 2004
  • Aug 31, 2004
the CCRM is inbetweeen the radiator and motor on the Passanger side right infront of the altnator. You can not replace a single relay inside of the CCRm you will need a new one if thats what your after
SanDogStang
79
Aug 31, 2004
  • Aug 31, 2004
ok i think i Know
Is it that thing that looks like a small module with a heat sink around it and attached to the inside fender? If so , that must have some small relays in it.
H
highhorseb
226
Finksburg, Maryland
Aug 31, 2004
  • Aug 31, 2004
SorsCode
20+ Year Stangneter
Jun 10, 2003
1,022
432
113
St. Louis, MO
Aug 31, 2004
  • Aug 31, 2004
nope thats the TFI this is infront the alt. its a little black box mounted on a bracket.
SanDogStang
79
Aug 31, 2004
  • Aug 31, 2004
OK Got it!
Thanks for the pic, boy im a dope. I will check with parts store and see how much this thing runs. I also bought the stator pickup for distributor which seems to solve the stalling problem or its the CCRM.
later on
mytight95
2,605
Dothan,Al
Aug 31, 2004
  • Aug 31, 2004
i would bet it is the TFI ignition if it cuts off when hot and starts etc. just fine when cold
jason
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
