CD Player Delete Plate
i will post up pictures and a write up on this power inverter install for you guys to check out i havent seen one on stang net and ill be doing this a little differently then others you have seen. I am removeing the cd player from the lower din and in the abs plate im makeing will have two ac power plugs, status led and cooling fan. the acuall unit will be mounted in the din itself. Switch relocated to insided arm rest. should look great when im done. Its a 140 watt inverter i ran a ps2 and tv off of one for hours so this should be good.
Here ya go, made by Speed of Sound. Here's pic of one model. http://www.speedofsoundllc.com/LimitedEditionParts.html
Definitely post some pix of that ... I'm interested in doing something like that. Right now I just have the pocket in the slot (bought it from Ford) ...
Pretty damn cool!
Well hopefully the car audio store here has abs cause i cant find it anywhere else except Ebay. So ill head out there today. If they got it ill start today. need to get some sturdy wire as well to extend wires. Havent opened up the din yet but im going to mount the unit (stripped) fan and all in the din. using the old units plates as templates. Ill get a good write up going today
