cecil power wheelie
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Thats a photochop, vids or it didnt happen! :D
Can you post some pics of the engine bay of that thing again? Hows the valve cover clearance by the master cylinder?
like slowmo?
its a little tight over there...
to get to the plugs i go under the master cylinder. but its also not running a standard windsor head
Are those c3, d3 or SC1's? Is the motor set back at all? Do you think you could get a power assisted brake setup in there?
SC1's
and not a chance in hell.. its lowered a good bit but dont think they moved it back any.
actually you may be able to make a hyrdoboost setup work if your still running power steering
