Center Caps
  • Thread starter Thread starter Pliskin
  • Start date Start date Dec 7, 2006
Pliskin
109
  • Dec 7, 2006
Hey all I have a quick question. I just go my wheels but the center caps are smaller on the front wheels than on the rears. Where can i get some mustang ones that'll fit both wheels? Help please!
Jenns01TA
37
Dec 9, 2006
  • Dec 9, 2006
You give me little to work with here Sport. Can we get some dimensions?
Pliskin
109
  • Dec 9, 2006
Yes ma'am! I bought these wheels for the back BLACK DEEP DISH BULLITTS and these for the fronts BLACK REGULAR BULLITTS. I'm not sure which one the OEM Ford caps will fit but I know the Deep Dish ones are bigger
PS CLICK THE LINKS FOR PICTURES
Pliskin
109
  • Dec 9, 2006
Ok so I found my Mustang center cap that I had lying around and put that in the wheel. it fit almost perfect on the DD rim but the front regular wheel cap is a tiny bit too small both in depth and diameter. So now I dont know what to do. Could I shave down the sides of the mustang piece? Come on I know there are more people with aftermarket wheels out there
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Dec 9, 2006
  • Dec 9, 2006
how about using the center caps that came with the wheels, and getting a new center emblem made for them?
Pliskin
109
  • Dec 10, 2006
How would I go about doing that? I think the diameter on the front wheel caps are the 2 3/8's inch and the ones on the rear (and from Ford) are 2 1/2 inch.
Jenns01TA
37
Dec 10, 2006
  • Dec 10, 2006
Hey choice of wheels Pliskin.
Most folks here that get aftermarket wheels usually use the center caps that come with the wheels, hence the lack of responses.
Check to see if any of the center caps listed on the link below will work with the two different sized wheel IDs you have. You may need to give them a call and speak to someone to get a better answer.
http://www.ehubcap.com/search_resul...ddedEnd=&txtPriceStart=&txtPriceEnd=&txtSale=
If the ID on the DD was fit without being loose, I would recommend hitting the oversized cap with a bench grinder. But, an undersized loose center cap is no better than an oversized one.
Let us know how it turns out.
Jenn
bigcat
May 1, 2005
3,015
7200 feet
Dec 10, 2006
  • Dec 10, 2006
i will ask the uphostry guys i work with. they have a cadillac with 20's that has their company logo in them. remind me if i dont post monday night with the info.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
O
Good all around perfornace-ish tires?
  • optionizerSS
  • Jan 25, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
TPony
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
N
1969 15x10 295's for rear. Modifications needed?
  • normg
  • May 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 2, 2026
GypsyR
G
