Centrifugal or Twin Screw?
imo for a street car that gets daily drive roots is the only way to go.
but if its a drag racer and you dont want to spend too much then a centri will do the deed
this should do
It's too simplistic to ask which is "better." Both transform the car in somewhat different ways. I think generally speaking you can make more peak power with a centri but more low-end with a PD. Either are wicked street fun. I like my PD on city streets at leisurely RPM but I bet a centri is a blast on on-ramps...
Wow thanks y'll for the info, yeah my eventual goal is a Livernois Stroker 298 2 valve short block, and I wanted to super charge it, but wasnt sure on which to go with, just trying to do a little research. Supposed to be getting my M.M. C/C Plates today. So the Centri. is for more high RPM, and the Twin Screw is more Torque at Low RPM? But at the same token different Strokes for different folks.
