Just finished the fox throttle body swap, also swapped out the cobra intake for a trickflow R, and swapped the 98 style Cobra hood for the cervinis R hood. The problem I am having is the rear of the R intake is hitting the rear of the hood. Has any one ran into this problem before? My engine is a 351w, and i am using a 3/8 inch spacer between the upper and lower. I am using the spacer because the fox throttle linkage looks like it would hit the valve cover without it. 3 questions.
1. Has anyone else ran into this problem?
2. Can anyone suggest a fix?
3. Any guess if the hofibertrends hood has more clearance?
Please help out, im stuck. Also if you have a hofibertrends hood, please share pics of the underside. Thanks.
