  • SN95 4.6L Mustang Tech
Change transmission fluid
  • Thread starter Thread starter m1tanker632
  • Start date Start date Jul 28, 2011
M
m1tanker632
  • Jul 28, 2011
I have a 2004 40th Anniversary pony, 5 speed. I checked the owners manuel to when the trans fluid should be changed. There is no info in there on that topic. So....is there a standard for changing the transmission fluid? Mileage? Age? Clutch replacement? It is a stock stang so tranny is probably T3650, but not sure
Maxpowers
859
Pittsburgh, Pa
Jul 28, 2011
  • Jul 28, 2011
Rule of thumb is 30,000 miles. Wouldn't hurt to flush the fluid if it's an automatic and you are unsure when the last time it was changed.
BULLITT5228
77
CENTRAL TEXAS
Jul 28, 2011
  • Jul 28, 2011
While you're at it, pull the shifter plate on to of the tyranny and clean that out. I had a bunch of gunk built up in mine. After I cleaned it out, I can shift gears with two fingers.
BULLITT5228
77
CENTRAL TEXAS
Jul 28, 2011
  • Jul 28, 2011
*tranny
Lugnuts
128
Evans, GA
Jul 29, 2011
  • Jul 29, 2011
Ford recommends auto trans fluid change every 30K.
Manual trans change every 60K.
FYI
Lugnuts
128
Evans, GA
Jul 29, 2011
  • Jul 29, 2011
Clutch life is dependent upon driver and driving style. Replace it when it convenient or it starts to slip.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
N
Complex changes need help
  • nomoremasks
  • Sep 15, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 15, 2025
nomoremasks
N
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
R
2004 mustang convertable need help please
  • realbkg
  • Mar 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2025
89ripper
