  • 2.3L (N/A & Turbo) Tech
Changing belts
  • Thread starter Thread starter Frumious B.
  • Start date Start date May 21, 2004
Frumious B.
96
Texas
May 21, 2004
  • May 21, 2004
What is tool that you release the belt tensioner with called? I thought it was a breaker bar, but I went to Sears to buy one and didn't see anything like what I needed. Would Autozone have been a better place to try?
351wcoupe
1,811
Manhattan, Kansas
May 21, 2004
  • May 21, 2004
You should be able to use a fairly long rachet and a 16mm socket for the ACC belt. I'm not sure about the A/C belt.
Lex
248
Halifax NS. Canada
May 21, 2004
  • May 21, 2004
I wouldn't waste money on a "Special" tool to loosen the tensioner. Just a racket will do , May want to put a pipe on the racket to get a little more torque. Thats my top secret
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
May 21, 2004
  • May 21, 2004
You do need a lot of muscle to release that tensioner, the hardest part is trying to hold the tensioner with one hand while you slip the belt out with the other. Even I have a hard time doing that with a 2 ft. ratchet, so you better make sure you have a cheater bar or some pipe or something.
P
Pro-Hawk
971
West Texas
May 22, 2004
  • May 22, 2004
They make a tool for this I never knew this No really even in Auto Tech we always used rackets
Like Lex and the guys said use a racket and its pretty easy to do. I mean you want pull your shoulders out of socket doing it. Its all about leverage so the longer the racket the easier it is also If you got one and it fits use a 1/2 drive racket it may be over kill but who knows
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
May 22, 2004
  • May 22, 2004
Simple, cheap 15 mm boxend will do the trick. But, your right, it does take a little muscle. Start the wrench in a position so that you will have the most leverage with your arm. Putting the belt back on, just make sure its on straight with all the pulleys so that it doesn't cause your belt to wear out too early.
StangGrrLy
Miss StangNet 2003
1,330
Regina, Saskachewan
May 22, 2004
  • May 22, 2004
I use a really looong ratchet (I call it a breaker bar too). It's the same thing I use to tighten lugnuts, it's like a foot and a half long.
....Now that you mention it, maybe it's time for me to change my belts....hmm....
G
GASCOOB
32
  • May 22, 2004
i use a long 0 offset wrench or just pull the belt on. easier when working on front drive car when theres no room up front of motor
P
Pro-Hawk
971
West Texas
May 22, 2004
  • May 22, 2004
Speaking of break bars...anyone know where I could buy a 3/8 drive break bar? I'm looking for something like Craftsmen/Snap on, so if I break it its no biggy. I have a 1/2 drive but some times the 3/8 small head is way easier to work with in tight spots I been doing like Tayrn with the 1 1/2 racket but I really would love a 2-3' 3/8 bar.
Sorry about the Hijack
Red_LX
73
129
May 22, 2004
#10
  • May 22, 2004
  • #10
Just curious, but what exactly are you guys referring to as "breaker bars?" I always called those long handles, with the socket fitting on the end that didn't actually ratchet, breaker bars, because they're just used to break stuff loose. Ratchets are just ratchets
Asha'man
1,909
Denver
May 22, 2004
#11
  • May 22, 2004
  • #11
I'm with Red, a breaker bar is a bar with a pivoting socket fitting. I also call the piece of pipe that you can put over a ratchet to lengthen it a breaker bar, although I've heard "cheater bar" too.
I changed both my belts in the Autozone parking lot with a single wrench - took all of thirty seconds.
Ash
P
Pro-Hawk
971
West Texas
May 23, 2004
#12
  • May 23, 2004
  • #12
Ash
Crap I can't spell that dudes name but he once said, "I could move the world if I had enough leverage." Everything is easy with enough leverage and that is what a break bar does. Here is a Break bar if you want to see one This one is kinda short and most people perfer 1/2 drive.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=42263&item=4302944755&rd=1
StangGrrLy
Miss StangNet 2003
1,330
Regina, Saskachewan
May 23, 2004
#13
  • May 23, 2004
  • #13
Yup, that's what mine looks like. It's a permanent fixture in my car, because my scrawny girlish muscles can't break anything loose lol.
P
Pro-Hawk
971
West Texas
May 23, 2004
#14
  • May 23, 2004
  • #14
Let me guess your guy only pen strips
Tensioner arm bolt
  • brandon4v
  • Jan 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 2, 2026
squeak93
Forced Induction V3 pulley change
  • JD1964
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 21, 2025
JD1964
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
