Changing clutch with longtubes
remove passenger side header. by dropping K.
Other will tell you that you can remove them without dropping K, but amount of time it takes to yank them out with K- member in place takes longer then dropping K menber. specially with dreaded 3rd starter bolt
drop k, remove starter, and start unboltin trans
SaleenGT2001 said:
there are 3 starter bolts???? mine only has 2 in it!
I was told that most people leave top bolt off. Other 2 will hold starter in fine.
But I left mine on, because i know I'll take K off to do any clutch work, and if K is off, 3rd bolt is right there
