  • SN95 4.6L Mustang Tech
Changing diff fluid
  • Thread starter Thread starter 2013 Geee T
  • Start date Start date Jul 19, 2006
1 of 2 Next Last
2013 Geee T
805
Oak Park, CA
Jul 19, 2006
  • Jul 19, 2006
Whats involved in doing this? Do I need to get a new gasket since Im assuming I have to take the cover off to drain it. Does it have a fill plug to fill it back up?
How much fluid and what type/brand/weight should I use?
d98gt
4,505
59
204
SE Texas
Jul 19, 2006
  • Jul 19, 2006
http://bullittarchive.com/1005.htm will help you out.
You'll need to buy some RTV to make your own gasket
P
Pennywise2
Banned
May 16, 2006
1,379
  • Jul 19, 2006
75W90 Royal Purple gear oil.
2013 Geee T
805
Oak Park, CA
Jul 19, 2006
  • Jul 19, 2006
Would the dealer have the gear oil and friction modifier?
Does it matter which gasket maker you use?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 19, 2006
  • Jul 19, 2006
Of course the dealer will have it. Use blue or black RTV for gasket.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Jul 19, 2006
  • Jul 19, 2006
i agree with killy, i use the black RTV and also use the RP 75W-90 diff fluid
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 19, 2006
  • Jul 19, 2006
Hey! I never said to use that overpriced Royal Purple snake oil!!! Use Motorcraft 75W-140synth and 4oz of FRPP friction modifier ONLY
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Jul 19, 2006
  • Jul 19, 2006
i never mentioned that you use it, i ment to say i use it personally on the cars i work on since i get it $5 a quart.............. my bad on the mix up
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 19, 2006
  • Jul 19, 2006
Just kidding anyways (but not kidding about the gear oil recommendation)
P
Pennywise2
Banned
May 16, 2006
1,379
#10
  • Jul 19, 2006
  • #10
You lose Killy you don't need to use a gasket.All you need is black
RTV.Also Royal Purple is one of the best differential oil you can use
and it is proven to work very we'll and millions of people use it and like it.
Useing Royal Purple you don't need friction modifier it already has it in it
so, on need to waste ten dollars for nothing.
d98gt
4,505
59
204
SE Texas
Jul 19, 2006
#11
  • Jul 19, 2006
  • #11
It says to use that FOR the gasket so you lose for attempting to correct someone when they weren't wrong
Royal purple is great, but not required by any means as the FMC will be fine
Cantslowdown
502
Mt.Home AR!
Jul 19, 2006
#12
  • Jul 19, 2006
  • #12
Black RTV and when we did mine at work the tec used two things of friction modifier..
d98gt
4,505
59
204
SE Texas
Jul 19, 2006
#13
  • Jul 19, 2006
  • #13
The book calls for 4 oz of it so does he add 2 bottles(8oz) for each vehicle?
P
Pennywise2
Banned
May 16, 2006
1,379
#14
  • Jul 19, 2006
  • #14
No need for the gasket you are wasteing your time and money
and all the need is black RTV.Useing Royal Purple it cuts out the need
for friction modifier so,if anyone should be shruging it should be you.
d98gt
4,505
59
204
SE Texas
Jul 19, 2006
#15
  • Jul 19, 2006
  • #15
I guess I could word it in another way so you'd understand what I believe Kilgore and I are trying to say.
The Black (or blue) RTV will act as the gasket. I'm not telling him to go out and buy a gasket
+1 extra
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Jul 19, 2006
#16
  • Jul 19, 2006
  • #16
you can use either but like many here will say is use the RTV
P
Pennywise2
Banned
May 16, 2006
1,379
#17
  • Jul 19, 2006
  • #17
+1 extra
I would only use black RTV.
Also I don't belive anything Killy says.
sunburstgold
58
#18
  • Jul 20, 2006
  • #18
Man this is way more complicated than it should be...
BurningRubber
1,865
24
58
Jul 20, 2006
#19
  • Jul 20, 2006
  • #19
werd...
only on :SNSign:
SigmaPride
170
#20
  • Jul 20, 2006
  • #20
I used RED RTV silicone gasket maker and it works fine, too.
1 of 2 Next Last
Proper Transmission fluid for a 84nwc t5
  • Sask84gt
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
Sask84gt
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
