I just used a heat source (hair dryer in my case). Heat it up, and just peel the emblem off. Then, you can roll the adhesive off the paint with your fingers. Be advised that the "Ford" emblem on the decklid is mounted with a stud, and therefore you will need to fill in the hole if you want to remove it.
