  • SN95 4.6L Mustang Tech
Changing fluids, need some guidance
  • Thread starter Thread starter mustang50v8
  • Start date Start date Nov 2, 2008
mustang50v8
548
847 Chicago Burbs
Nov 2, 2008
  • Nov 2, 2008
im going to be changing the trans and diff fluid out on my Cobra before it goes back on the road so i want to know what fluids to use.
the trans is a T-45 and the diff has 4.10 gears.
1. the T-45. i will get some mobile 1 ATF. how much fluid goes in there? i have heard 3, 3.2, or 4 quarts. i just want to know for sure.
2. the diff. again i will probably go with mobile 1 (or something else if reccomended) but how much fluid and i think there is something that needs to be added (friction modifier?) what exactly is it and how much of it?
i want this to be done right the first time, because i dont want to have to do this again for a long time.
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Nov 2, 2008
  • Nov 2, 2008
With the rearend i think its something like 2 bottles of fluid(not sure how much is in the bottles) and the friction modifier comes in a little bottle and you put all of it in there. I used Royal Purple rearend fluid
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Nov 2, 2008
  • Nov 2, 2008
T45 and TR3650's take almost 4 quarts of ATF. Have the car on level ground. Fill it through the shifter with the fill plug out. Put a catch can under the car and when you see fluid dripping out of the fill plug, wait until it stops dripping and put the fill plug back in. This ASSURES you perfect fill up.
8.8 rear ends take almost 3 quarts of gear end fluid and 4oz. friction modifier. Put the friction modifier in first. You'll have to jack the car up to get under it. Treat the rear end the same as the transmission. Once you see fluid dripping out, set the car on level ground, let the fluid stop dripping out, then put the fill plug back in.
You do NOT want to overfill either unit because this could cause the seals to blow out. The rear end vent will usually let out access fluid, but only if it's a tad overfilled. If it has too much in there, it will drip out of the wheel seals and the inside of your wheels get coated with fluid.
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
