Changing Fuel Pump
Sunday,I cut a rectangle hole out of the trunk floor so I could swap the pump a LOT more easily.I went to Lowe's and bought a 12x12 steel panel,made a custom cover for the hole I cut out,put a bead of sealant down,installed the cover,and put 7 small button head screws in to hold it all together,re-installed the carpet,done.I can change the pump in 10 minutes now.The hole took 5 minutes to cut out.Once the carpet is installed,you can't even tell anything was done.At first I didn't want to do it,but afterwards,I'm glad I did.If for some reason,somewhere down the road,the pump gives,and I'm a ways from home,no worries,no hassle.
Back when we had our Taurus SHO the guys on the SHO forums used to do this too. Pretty neat trick !
Honestly debating the hole cutting. I've dropped my tank so many times, it's not hard, it just sucks.
Not like I'm saving my car for a museum anyways
PICS!!
mine is pretty much the same,just not quite as sloppy.LOL.I made the hole big enough that I didn't cut myself up,but not so big that it was just unnecessary.I drilled the hole above the tank with a bit that was about 3/4 of an inch in diameter and looked down to with a flashlight to get the positioning of the pump right.The Dremmel made easy work of it,and as i stated,VERY easy,and VERY much worth the time.It took my about 30 minutes from start to finish,including pulling the trunk panels out and the carpet back.The Thunderbird trunk is different than the Stang,but the concept is exactly the same. The pic above in the link that shows the fuel pump assembly through the Stang's newly cut trunk,looks just like the Bird's.Red plug,fuel lines and all.Once the hole is cut,and the panel is made to cover it,you'll ask yourself why you didn't do that the first time you swapped a pump out,and now,you can easily change a fuel pump literally anywhere (providing you can get parts wherever "anywhere" is) in literally minutes with two screwdrivers and a hammer.
