I'm a bit confused. I bought a 98 GT 5 speed and I have read that if you change the gears out back you need a Speedcal to correct it. I've also read that you might be able to simply swap the drive gear on the cable in the tail shaft.
So which is it? Anyone done this? Someone must have. Absolute accuracy isn't my concern. As long as it's reasonably close (+/- a little bit is ok), I'll be happy.
