  • SVT Tech Forum
changing my clutch
  • Thread starter Thread starter Holik95
  • Start date Start date Apr 14, 2007
H
Holik95
90
Granite City,IL
Apr 14, 2007
  • Apr 14, 2007
I'm changing my clutch tomorrow and have a couple questions. Do I need any special tools? Should I change the fluid in the tranny? What kind of fluid should I buy and how much? Any other advice you can give me would be great. Its my first time and I just wanna make sure I have everything. Thanks.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 15, 2007
  • Apr 15, 2007
My advice is to not try and change your clutch...
TheCrazy1
70
  • May 1, 2007
Yeah, a clutch swap is a pretty big job, but if you have access to a car hoist and transmission jack, then it's a lot easier. You'll want to have a clutch alignment tool for when you tighten the pressure plate down against the flywheel. It's always a good idea to get the flywheel resurfaced and replace both clutch bearings as well as the front seal on the transmission while you're in there. The later model Mustangs use automatic trans fluid and I believe it's 3 quarts. It's a good idea to drain the trans before you remove it to lighten it a bit plus prevent spilling if it gets tipped. Personally, I'd pay to have it done, but if you have the means and motivation then have at it!
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
May 2, 2007
  • May 2, 2007
I think the official capacity for the T56 on the Cobra is 3.8 quarts. Ford recommends Dexron III (ATF). Personally I run the full synthetic Mobil 1 ATF in mine. Others have successfully run Red Line D4 ATF, Red Line MTL, Valvoline Durablend ATF, Amsoil ATF, GM Synchromesh or Quaker State Synchromesh.
Not sure if our aluminum flywheels are capable of being resurfaced either.
U.M.
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Jun 14, 2026
Mindseye007
L
2006 mustang gt has high clutch bite
  • leevikisley
  • Feb 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 22, 2026
leevikisley
L
Engine Which fan clutch ?
  • AnthonyA1234
  • Jun 22, 2026
Fox 5.0 Mustang Tech Sep 19, 2026
Mustang5L5
  • SVT Tech Forum
