Changing Reverse To Standard Rotation H2O Pump
  • Thread starter Thread starter Shotyme
  • Start date Start date Dec 19, 2005
Shotyme
105
Assiniboia, Sk
Dec 19, 2005
  • Dec 19, 2005
I have an 88 gt with a reverse roational and i was wondering if a standard rotation pump can be swapped on instead.
87GTSnake
96
PA
Dec 19, 2005
  • Dec 19, 2005
No it cant, you have to use the stock style reverse rotation because of the way the belt is routed.
J
jerryD
1,061
Gladstone, MO
Dec 19, 2005
  • Dec 19, 2005
yes it can be done. you just have to reroute your belt. why do you want to switch over?
blk9450
1,507
your moms bed
Dec 19, 2005
  • Dec 19, 2005
i saw this thread title and thought you wanted to change your reverse to a forward gear, like 6th, that would be awesome... **** reverse
oh and i clicked on it from the main forum page, so it cut the title down, im only 3/4 retarded
Shotyme
105
Assiniboia, Sk
Dec 20, 2005
  • Dec 20, 2005
The reason I am wanting to switch this over is bcause i am looking to get a bracket and pulley combo from march. And it is going to use to serpentine belts but it requires a standard rotation water pump to achieve the double belt.....
Shotyme
105
Assiniboia, Sk
Dec 20, 2005
  • Dec 20, 2005
does anyone know where i can find a standard roatation water pump for a 5.0 302 if they in fact exist?
Shotyme
105
Assiniboia, Sk
Dec 20, 2005
  • Dec 20, 2005
anyone??
351LX
1,007
Regina, Saskatchewan
Dec 21, 2005
  • Dec 21, 2005
I put an 88 HO motor into my old 78 Zephyr and I just used the original 78 water pump which was standard rotation and didn't have any problems.What I would do is do a search on Car-part.com for a water pump from a known standard rotation vehicle (any 302 powered passenger car from the 70's) which will give you a pretty good idea of what applications you need.You probaly want an aluminum one, mine was cast iron.A trip to the local wreckers might give you the same info, look for something with a v-belt or the belt on the left side of the pulley.
MrKwik
1,008
Kansas City, Kansas
Dec 21, 2005
  • Dec 21, 2005
I think pretty much any older 302 pump should work. I have heard That they dont cool as well as the reverse rotation pumps but for the life of me I cant figure why that would be.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
C
Engine Do I have a standard or reverse rotation pump?
  • Cobraii1976
  • Apr 27, 2024
2K
Fox 5.0 Mustang Tech Apr 28, 2024
General karthief
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
coil pack bracket
  • SteveG94GT
  • Apr 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 11, 2026
SteveG94GT
