  • 1994 - 1995 Specific Tech
Changing steering wheel.
  • Thread starter Thread starter super302
  • Start date Start date Dec 27, 2004
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
Dec 27, 2004
  • Dec 27, 2004
teh current steering wheel (outer ring, not center) is f'ed to hell, so i accuired a new one (a.k.a. previous owner gave it to me when i bought the car) i will be changin it soon but am worried about the airbag. I read in an article of 5.0mustang magazine (november 2004) when they change the gauges in a 98 cobra, they say to unhook the battery, then just two side bolts on steering wheel and one t-50 torx bolt. do i have to worry about the airbag going off if battery is disconected.
Thanks,
Patrick
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Dec 27, 2004
  • Dec 27, 2004
It is still possible for it to go off. When you have the air bag off lay it down with the air bag facing up that way if it goes off it doesn't become a fly missle. That one thing I learned at ford when I worked there.
super302
May 29, 2004
2,878
Davenport, IA
Dec 27, 2004
  • Dec 27, 2004
so is there a sure-fire way that it won't go off?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Dec 27, 2004
  • Dec 27, 2004
Yeah don't slam them or bang them really hard on anything. The chances of it going off are slim but the chance is still there just use caution and common sense.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Dec 27, 2004
  • Dec 27, 2004
I treat the airbags like I would a loaded gun. Treat it carefully and you should be fine. Due to some messed up wiring, I replaced my whole steering column but kept my steering wheel. Your instructions are basically right. When you unhook the battery, leave it unhooked for 15-20 minutes before you touch the airbag. The airbag system still holds a minor charge for a short while, but it will discharge within 15-20 minutes.
You'll also need a steering wheel puller; most shops rent one. The steering wheel pops off real easy within a few turns of the puller. There are two threaded holes in the steering wheel that are used by the tool. Just be careful not to strip on of them. If you do, you'll have to drill out the hole and tap it. It can be done, but it's a pain.
Good luck!
super302
May 29, 2004
2,878
Davenport, IA
Dec 27, 2004
  • Dec 27, 2004
thanks guys,
according to the article, it says just wiggle the wheel back and forth and it will come off with ease.
It's been disconected for a few hours+more hours tommorrow, i'm playing it EXTREMELY safe.
slvrbullit302
986
Alabama
Dec 27, 2004
  • Dec 27, 2004
super302 said:
thanks guys,
You will need a steering wheel puller as I have just done this to mine. As for the AIRBAG, unhook the battery, then go in the car and press the brake pedal a couple times to discharge any stored energy in the cars electrical system, then remove airbag from steering wheel center and unplug the airbag should be ok. You have to remove the airbag in order to get the steering wheel off.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
Question on Chime Module and Airbag controller?
  • stevedjarrell
  • Jun 12, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2024
stevedjarrell
J
dead spot (loose) in center of steering wheel
  • JTD2001
  • Sep 11, 2023
  • SN95 4.6L Mustang Tech
3K
SN95 4.6L Mustang Tech Aug 18, 2026
DadLife0724
D
Electrical Manual 2003 GT 4.6L coupe that will not start. Thoughts? Resources?
  • DapperFish
  • Jan 17, 2024
SN95 4.6L Mustang Tech Jan 22, 2024
PSKSAM2
P
