Changing timing cover gasket
  • Thread starter Thread starter 92Patrol5.0
  • Start date Start date Feb 23, 2006
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Feb 23, 2006
  • Feb 23, 2006
When changing the gasket, what's the best way to keep coolant from spilling into the oil pan? When I took the timing cover off about a year ago due to snapping one of the oil pan bolts in it, I got coolant in the oil pan. I did the best I could to cover the top of the pan but it didn't matter, coolant still got in there. I did my best to clean the coolant out of the pan but would be easier if there was any way to keep it from happening to begin with. Didn't know if there was some kind of trick. I guess the only way would be to drain the coolant from the block?
bill302
2,131
alabama,gadsden
Feb 24, 2006
  • Feb 24, 2006
you got it drain coolant....
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Feb 25, 2006
  • Feb 25, 2006
Where is the coolant plug to drain the block? I've never done it before. Is it going to be rusted up and seized in there?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Feb 25, 2006
  • Feb 25, 2006
If you drain it from the radiator, it should be low enough in the block to allow you to remove the front cover...
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Feb 25, 2006
  • Feb 25, 2006
That's what I did last time, and I still had some spillage into the pan. Was just wondering if there was any sure way to eliminate this from happening, or if I just have to flush the pan out well before reinstall.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Feb 25, 2006
  • Feb 25, 2006
Perhaps my outcome was different because I had the front of the car jacked up in the air -- that may be something to consider. I view an oil change after a job like that as part of the procedure --
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Feb 25, 2006
  • Feb 25, 2006
Thats what I did last time. I didn't get huge amounts of coolant but enough to make it a pain. I cleaned the pan out best I could, put fresh oil in and only ran it for a few hundred miles then changed the oil again. Just to make sure I didn't leave any coolant circulating through the system.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
